1995 Jeep Cherokee Headlight Problem
1995 JEEP CHEROKEE
170,000 MILES • 4 CYL • 2WD • MANUAL
RJAL25
I almost have the same problem like the person who has a jeep cherokee on the forum. My problem is just a tiny bit different though. When I pull the headlight switch, nothing turns on except the parklights. But when I hold on to the highbeem/wiper switch, the highbeam turns on only if you hold on to the highbeam/wiper switch. I check the fuse and it's ok. Don't know what to check next except for the switch itself. Just want to make sure i'm on the right track.
Thank you,
Ric
Dec 18, 2007 at 5:41 PM
AGORDON1000
Hi Ric
did you manage to sort this out, as I have exactually
the same problem but am not able to solve
any advice would be greatly appreciated
thanks
Andy
Feb 18, 2019 at 5:07 AM
RJAL25
Hi Andy,
It was defenitely the switch that got burned off, can't barely see it with the naked eye. I used the tester to make sure there was continuity and there wasn't. Bought a new switch at Auto Zone for $14.99.
Ricky
