2001 Jeep Grand Cherokee Misfire Smoke
NANC
I have a 2001 GC Limited with 55,000 mi. It has Auto Tranny, 4-wheel drive with a V-8 engine. As I was drving down the highway (60mph) it started to shudder and white smoke billowed from the exhaust along with odor. No warning lights were on and all guages were reading appropriately. I reduced my speed until I reached my destination (2 mi) and shut it off. I was able to start it again, but it took a long time for it to turn over. I proceeded at a slow speed and then the MIL came on. I had it checked at a local garage and they said the only thing it said when it was scanned was that it was misfiring on two cylinders. He is guessing it is the fuel injector/pump, but is hesitant to try it since it is really spendy. Are there any other possiblities before I pursue this course of action? Thank you for your help!
Jun 16, 2007 at 2:36 AM
SERVICE WRITER
  • 9,123 POSTS
What I would try is a professional fuel injection cleaning first.
However, the fuel pump fuel pressure can be checked, and the offending cylinder's injectors can be swapped with the non-offending cylinder's injectors to see if the misfire moves to other cylinders.
Jun 16, 2007 at 12:46 PM
Suggested Repair
Start with a professional fuel-injection cleaning. Check fuel-pump pressure, and swap the misfiring cylinders' injectors with good ones to see whether the misfire follows the injectors.
Conversation Summary
The owner of a 2001 Jeep Grand Cherokee Limited reported highway shuddering, white exhaust smoke and odor, a hard restart, and a later MIL. A scan showed misfires on two cylinders, and a shop suspected the fuel injectors or pump. The expert recommended a professional injection cleaning first, a fuel-pressure check, and swapping injectors to see whether the misfire moves.
