1996 Jeep Grand Cherokee Runs Rough
KMS27
Hi i have a 96 jeep grand cherokee with a v8 with about 119000 miles on it....last night i was on the highway when the temperature gage went off...i drove to the next exit and had the car towed home...took it to a repair shop where they replaced the lower radiater hose...however now it is running very rough and crappy...someone said my valve gaskets may have blown...does this sound right and if so how much am i looking at?
Aug 12, 2007 at 3:36 PM
DPWD23
  • 136 POSTS
I'd have proper diagnostics ran on the vehicle. To diagnose valve seals being bad they have to do more testing than "it runs crappy".
Over heating can cause major damage, but don't get taken for a ride. Get wirtten estimates, and shop around. If they are all shooting very high, check a local junk yard to see what they would charge to swap an engine for you. You may walk away with an engine w only 30k miles on it for less than the fix of yours. they usually give a 30 day guarentee too.
Aug 17, 2007 at 6:12 PM
Suggested Repair
Have proper diagnostics performed rather than assuming valve seals or gaskets failed from rough running alone. Overheating can cause major engine damage, so get written estimates and compare shops. If quotes are very high, compare a used or junkyard engine swap, which may cost less and often includes a short warranty.
Conversation Summary
The owner of a 1996 Jeep Grand Cherokee V8 with about 119,000 miles overheated on the highway and had the lower radiator hose replaced. The engine then ran very rough, and someone suggested blown valve gaskets. The expert advised proper testing instead of assuming valve seals failed, getting written estimates and shopping around, and considering a lower-mileage used engine if repair costs are very high.
