2000 Jeep Grand Cherokee Black Smoke
SUMMERSPOP
I have a 2000 GRAND CHEROKEE 4.7L with 120,000. I changed the plugs in it about a month ago and shortly after I noticed black smokoe from the exhaust when ever I would really give it some gas. I read up and learned that it could be caused by wrongly gapped plugs so I removed them and checked the gap. The gap were larger than the required setting so I corrected the gap all all 8 plugs but the smoking continues. One interesting thing I noticed while regapping the plugs is that all 4 plugs on the passanger side looked brand new but all 4 plugs on the driver side were covered in black soot. Any suggestions?
May 7, 2007 at 5:16 AM
MERLIN2021
  • 17,250 POSTS
Change the 02 sensor on the offending bank, running too rich!
May 7, 2007 at 7:57 AM
SUMMERSPOP
Thanks for the tip, I will give it a try and let you know.
May 7, 2007 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
OK...and please vote and donate!
May 7, 2007 at 8:13 AM
SUMMERSPOP
I was looking around about the O2 sensor and you said to replace the O2 sensor of the offending bank. The diagram I found shows one near the front of the exhaust and one after the CC, which one should be replaced?
https://images.2carpros.com/forum/automotive_pictures/72843_oxygen_47_1.jpg
May 7, 2007 at 8:37 AM
MERLIN2021
  • 17,250 POSTS
Front one...
May 8, 2007 at 1:52 AM
Suggested Repair
Replace the front (upstream) oxygen sensor on the driver-side bank that is running rich and sooting the plugs.
Conversation Summary
A 2000 Jeep Grand Cherokee 4.7L began emitting black smoke under hard acceleration after a plug change. Rechecking the plug gaps did not stop it, and the driver-side plugs were sooty while the passenger-side plugs looked clean. The expert attributed the smoke to a rich condition and advised replacing the front oxygen sensor on the affected bank.
