1988 Jeep Cherokee Black Smoke Poor MPG
JENALLI6799
I have a 88 jeep cherokee 200000 miles 6 cylinder 4x4 and I am getting 10 miles to the gallon, and there is a lot of black smoke what could the problem be???
Sep 6, 2007 at 3:46 PM
GRICHARDS
  • 57 POSTS
Black smoke generally means that your fuel mixture is too rich, which makes sense if your gas mileage is that bad - burning more gas per mile travelled...
Have you had a decent tune up in the recent past? Air filter could be clogged/dirty, Timing off, Plugs fouled, dirty carb or fuel injectors, while you're at it check the distributor cap for cracks, burned terminals inside, check condition of rotor...just a good tune-up would be a good starting point. If problem still exists, post back - an Oil Company spy may have reprogrammed your engine computer in the middle of the night, telling it to run rich so you'll have to buy more gas $$$$ - Nahhhhh! Good Luck!
Sep 7, 2007 at 11:29 PM
Suggested Repair
Black smoke and very poor mileage point to a rich fuel mixture. Start with a tune-up: inspect or replace the air filter, spark plugs, ignition timing, distributor cap, and rotor, and clean the carburetor or fuel injectors.
Conversation Summary
The owner of a 1988 Jeep Cherokee with about 200,000 miles reports 10 mpg and heavy black smoke. The expert explains that black smoke indicates a rich mixture and recommends a basic tune-up covering the air filter, plugs, timing, distributor cap and rotor, and carburetor or injectors, then following up if the problem remains.
