2004 Jeep Cherokee Exhaust Tick
SCHRADER4415
'04 Cherokee 4.7 HO 52k
Makes a ticking sound most pronounced at start up.
Anyway to fix other than disassemble??
Nov 21, 2007 at 12:40 PM
  • 31,937 POSTS
Hi there,
If you use a length of rubber hose as a stethoscope, you will be able to locate exhaust noise, If manifold gasket leaking, you will have to remove to replace failed gaskets.
Mark (mhpautos)
Nov 21, 2007 at 1:01 PM
Suggested Repair
Use a length of rubber hose as a stethoscope to locate the exhaust noise. If the manifold gasket is leaking, the manifold must be removed to replace the failed gaskets; no non-disassembly repair was recommended.
Conversation Summary
Owner of a 2004 Jeep Cherokee 4.7 HO with 52,000 miles reports a ticking sound most noticeable at startup and asks if an exhaust manifold leak can be fixed without disassembly. Expert advises using a rubber hose to pinpoint exhaust noise and states that a leaking manifold gasket requires removal to replace the failed gaskets.
