1994 Jeep Cherokee Overheating
Suggested Repair
Do not run the air conditioner, because it can make overheating worse. Use full heat so the heater core helps cool the coolant. Check for a failing water pump or cracked engine water jacket, clean debris from the radiator and front cooling fins, and confirm the cooling fans work.
Conversation Summary
The owner of a 1994 Jeep Cherokee with about 123,000 miles reports overheating after a thermostat replacement and suspects a leaking radiator. They ask whether the air conditioner can be used for cooling until the radiator is replaced. The expert says running the air conditioner will worsen overheating and recommends full heat so the heater core provides extra cooling. The expert also suggests checking a failing water pump or cracked water jacket, cleaning the radiator and front cooling fins, and verifying that the cooling fans work.
