I have been having problems with my jeep overheating recently. I replaced the thermostat and the water pump and then the top radiator hose blew off, so I replaced that. Also I noticed a small leak in the inlet side of the radiator. I put radiator stop leak in it and it seemed to have fixed it. Then I was drivign it and the temp light came on again so I pulled over I heard a hissing sound on the inlet side of the radiator and then all of a sudden it blew up! The end of the radiator just blew off!! I just bought a new radiator thinking that maybe the old one was clogged but im hoping this will fix it. Do you think there could be other problems making it overheat like this? Thanks so much for your insight.
Sep 12, 2007 at 4:15 AM
