You can check it yourself. First check to see if there is power to the motor when you hit the switch. If there is, the motor is bad. If there isn't power, go to the switch and check if the switch is getting power. If it is, check if there is power out. If none out, replace the switch. If there is no power to the switch, then you need to follow the wiring to see where there is a break in the power. All you need to do this is a test ligth.
SPONSORED LINKS
Saturday, January 9th, 2010 AT 11:56 PM
