2000 Jeep Cherokee WINDOWS
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSOUTH09
MY DRIVERS SIDE DOOR PANEL ISNT WORKING AND WINDOWS ARE STUCK
May 26, 2008 at 2:59 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:3d28b25481="GSOUTH09"]Electrical problem
2000 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 100000 miles
MY DRIVERS SIDE DOOR PANEL ISNT WORKING AND WINDOWS ARE STUCK[/quote:3d28b25481]
Did you try putting the other windows up using there respective door panel controls? If so and still don't work look for Power Window Relay in power distribution block under hood. Once you find it pull it, look at numbers on it. Then look and see it any of the other relays have that same number. If so swap them and see if the windows work. If so replace relay...
Post response here....
May 26, 2008 at 3:51 PM
