If you check the circuit breaker with a testlite by placing a good fuse in the proper place turn the ignition on make sure you hook your test light up to a good ground then touch the test light probe to each of the 2 metal pins on the back of the fuse if the testlight lights up in both spots then I would check your switches on alot of cars if the master window switch is bad the others will not work either
Monday, September 21st, 2009 AT 11:44 PM
