1995 Jeep Cherokee Power windows
KNAHOI
  • 1995 JEEP CHEROKEE
Interior problem
1995 Jeep Cherokee 6 cyl Two Wheel Drive Automatic 122k miles
All for windows have stop working and are stuck ½ way up. I checked all the fusses, all are OK. I don’t know what to do from this point and can not afforded to take it to the shop.
TY4YT !
Monday, September 8th, 2008 AT 4:03 PM
SCULLY719
First you need to find out if the window motors are getting power. If so, the you have a broken ground wire. Since its all four, check drivers door wiring harness for broken wire. Its gonna be a black wire. Slide back the rubber boot covering the harness and look for broken or frayed connections. A new wiring harness is probably alot of money, so if you can get to it try to splice the peices together. Hope that helps ya.
Monday, September 15th, 2008 AT 3:29 PM
KNAHOI
I for got to mention that the car would not start, It would turn over. It acted like it was flooded, not getting gas or was not getting spark. The fuel was getting up to the ejector so I stop there and went on to spark. It was not getting spark at the d-cap so I replaced the starter coil. The car still will not start but the windows went up.
Monday, September 15th, 2008 AT 3:59 PM
