2000 Jeep Cherokee problems after head gasket change
JAREDHOTROD
Engine Mechanical problem
2000 Jeep Cherokee 6 cyl Four Wheel Drive Automatic
I have a cousin who changed his head gasket on a 2000 jeep cherokee with the straight 6 cyl. It has the "distributerless" ignition system. After he finished and started it, the engine revs up to redline, almost like at full throttle. I went to help him and see what I could do, and sure enough it does immediatly rev right up to the redline and stays there. Thought it could be the idle air control valve,checked it with an obd machine and even said it,replaced it and still does it. Checked "very" thoroughly all vaccuum and emission lines , no leaks or cracks whatsoever ! Took the valve cover off and made sure all rocker arms ,push rods and valves are moving correctly.I have never come across this before in all my years. He insists everything he did was done correctly, he is very keen on doing things slow and taking his time and checking everything twice. I would appreciate any help or suggestions. I am completely baffled and confused on this one. I am wondering at this point if it is a jeep thing and I just dont understand, but it would be nice if he could drive it again.
Sep 8, 2010 at 1:26 PM
WRENCHTECH
  • 20,760 POSTS
In order for the idle to rise, it has to be getting unmetered air in to the system somewhere. You need to find out where. It could be a bad vacuum leak, a throttle plate not closing all the way or a hose off somewhere. One way or another, air is getting into the intake.
Sep 8, 2010 at 1:44 PM
