1995 Jeep Cherokee NEed Help Bad ON this
1995 JEEP CHEROKEE
178,000 MILES • 6 CYL • 2WD • AUTOMATIC
MADREAPER
Start off I pulled the head off to change the gasket then. also change manfold gaskget as will .hand put ever ything back together reconnected everything as well.also change the plugs and cap router and cap and wires .now I'm not getting no firing from plugs or from cap at all .this was running before I change the gaskgets and all .
p.S i KNOW RELAYS WORKING FUSE'S ALL GOOD
Mar 8, 2009 at 1:39 PM
BMRFIXIT
  • 19,053 POSTS
check and make sure the crank sensor is connected
check ASD relay if clicking on when cranking
check and make sure all you plug wires are connected
Mar 8, 2009 at 1:45 PM
MADREAPER
I checked the ASD relay I check it on my 2000 jeep it works since its the same relay
Mar 8, 2009 at 2:32 PM
BUICKRODGUY88
  • 8 POSTS
if it was running before u changed gaskets sounds like theres a little something your missing retrace your tracks and also did you take all the plug wires off at the same time? if you did check plug wire order.
Mar 11, 2009 at 4:41 PM
