It takes 3 things to make a car run compression fuel and spark check to see if you have all 3. But first check for spark if no spark than pull distributor cap and see if rotor is turning than check fuel pressure if good pressure about 50 than check compression and let me know I will help as much as I can
SPONSORED LINKS
Tuesday, October 14th, 2008 AT 6:43 PM
