1994 Jeep Cherokee starting
JERRY G
  • 1994 JEEP CHEROKEE
  • 6 CYL
  • 4WD
  • 125,000 MILES
My Jeep Cherokee wont start at all when the ignition key is turned, not even a click. Battery looks fine. Is it true there is some type of strap or band in the console(connected at the shifter) someplace that engages a switch or something allowing the vehicle to start?
Wednesday, December 19th, 2007 AT 3:40 PM
When you turn key to On position do you see all the lights that normally comes On. If not double check the battery and its connections make sure it shiny, clean/tight. If it checks out you might be dealing with a problem with starting system. Which starts at the ignition switch, transmission range sensor or neutral safety switch, starter relay, and starter itself
Or I could be wrong and its coming from the security guard system/auto theft deterrent system.
Any further assistance needed come on back
Wednesday, December 19th, 2007 AT 3:59 PM
