2000 jaguar s-type won't accelarate
ARRED209
i have a 2000 jaguar s-type 4.0 car was working fine until last night i started the car put it in gear but it wouldn't accelarate. and the check engine light came on.if i put the car in driver or reverse it will move just at the speed any other car would with out accelerating but when i press the gas peddle it won't do anything
May 23, 2006 at 8:20 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like it could be a fuel pump or Mass Airflow Sensor
Sep 12, 2006 at 7:49 AM
FSTRANGER302
  • 117 POSTS
the car is in limp home mode when the computer sees a major problem it locks the trans into 4th gear only limp in mode. there is a hard fault in the computer. usally a throttle motor or trans fault will cause this
Sep 20, 2006 at 1:17 PM
