1997 Jaguar XJ6 idle regulator
PICCI
  • 1997 JAGUAR XJ6
  • 6 CYL
  • FWD
  • 250,000 MILES
When you press the gas peddle of my jaguar xj6, it jolts and sometimes when I try to start the car, it wont start up. I was told I need a new idle regulator. I have been looking everywhere online and cant seem to find a used idle regulator. Where can I find one?
Thursday, July 9th, 2009 AT 6:13 PM
DAVE H
  • 13,384 POSTS
Throttle Position (TP) Sensor
TP sensor interprets throttle position and movement to identify idle, acceleration, and full throttle positions.
IDLE SPEED
Idle Air Control (IAC) Valve
IAC valve is attached to intake manifold. 6.0L is equipped with 2 IAC valves. One IAC valve is mounted to each throttle body. On all models, IAC valve contains a stepper motor-driven valve, which varies volume of air by-passing throttle valve to maintain idle speed.
Sunday, October 25th, 2009 AT 7:56 AM
