1997 Jaguar XJ6 Not starting
BUDSWILLEY
  • 1997 JAGUAR XJ6
  • 6 CYL
  • 160,000 MILES
The car at times will start and run, but will not stay running on its own. It will always fire and run, but not keep running on its own. It is like the advance is not working. Then after a while, it will start and stay running on its own.
This usually happens when you first start the car, but has happened as the car is in traffic.
My thought is that there is a problem with the control box, or maybe a switch that is operated by the ignition switch that operates the control box.
Wednesday, March 4th, 2009 AT 7:50 AM
JAMES W.
  • 2,394 POSTS
Sounds like the idle speed control unit isn't functioning. This ais located in the top of the intake manifold in the middle of fuel injector row. It may just have to be removed and cleaned.
Monday, March 9th, 2009 AT 6:00 PM
