Hi I have a 1990 Jaguar XJS in the shop and there is fuel pressure going to the fuel injectors a I replace the pump and its working, I also replace the crank angle censor but the injectors are still not working. I do have power going to the coil and spark comming from the coil. Can any one help me with this problem. My client is loosing patience with this car. Thanks! Lance
SPONSORED LINKS
Wednesday, October 22nd, 2008 AT 1:08 PM
RACEFAN966
MECHANIC
Have you hooked up a noid light and checked for actuall injector pulse? Get back to me and we will go from there.
Wednesday, October 22nd, 2008 AT 9:46 PM
SPEEDLANCE007
MEMBER
Hi yea the injectors are working. There is no power going to the fuel pump. Thanks Lance
SPONSORED LINKS
Friday, October 24th, 2008 AT 1:04 PM
RACEFAN966
MECHANIC
Have you checked or replace the fuel pump relay? I am not sure where it is at I will have to check at work on my Mitchell1.
Saturday, October 25th, 2008 AT 8:46 AM
SPEEDLANCE007
MEMBER
Hi, Did you find the location whereabouts of the fuel pump relay? I still can't find it. Thanks Lance
This is for a 1990 Jaguar xj6 with a inlne 6 cyl engine.
Monday, October 27th, 2008 AT 3:02 PM
RACEFAN966
MECHANIC
I will check today I am sorry I got busy and I don't do any work on Sunday's but will check while at work today.
SPONSORED LINKS
Tuesday, October 28th, 2008 AT 9:07 AM
SPEEDLANCE007
MEMBER
Have you fopund the location of that pump relay yet! 1990 Jaguar xj6. Lance
Wednesday, October 29th, 2008 AT 3:17 PM
RACEFAN966
MECHANIC
I am still looking I have one more book to go through today when I get to work I will do that hopefully I will find in this one. Sorry it is taking a few but I have to do this on my time and sometimes there isn't much of that. I will get back to you tonight or sooner ok.
Thursday, October 30th, 2008 AT 10:27 AM
RACEFAN966
MECHANIC
It is in the trunk. On the right hand (passanger) side there are a bank of 3 relays. It is the one closest to the window or the furthest one in. I hope this helps.
