1990 Jaguar XJ6 1990 Jaguar no start
SPEEDLANCE007
  • 1990 JAGUAR XJ6
  • 6 CYL
  • 95,000 MILES
Hi can any one tell my why this jaguar xjs will not start? It turns over but will not start and run. We installed a new fuel pump and there is fuel pressure @ the fuel rail, but it seems like the injectors are not working. Any help would be greatly appreated.
Monday, September 22nd, 2008 AT 6:07 PM
2CARPRO JACK
  • 11,533 POSTS
Any spark? Need to get a noid light to verify no injector pulse. Check to see if you have power at thecoil with key on, if so other wire should flash test light when engine cranked, if not you may have a crank angle sensor that is bad. If the ECM doesnt see the engine turn it wont fire the injectors or create spark
Friday, September 26th, 2008 AT 8:28 AM
