HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Jaguar
S-Type
Engine
Air Filter
Replace/Remove
2000 Jaguar S-Type
JOSHNAVE1979
MEMBER
2000 JAGUAR S-TYPE
V8
2WD
AUTOMATIC
130,000 MILES
Changing plugs and there is oil on the plugs and on the air filter what needs to get done to fix this
Friday, October 15th, 2010 AT 2:06 AM
JAGTECH360
MEMBER
Cause: Partial load breather is plugged. Clean it with a small drill bit but DO NOT drop the drill bit into the camshaft cover.
To remedy the oil in the spark plug wells you will need to replace the camshaft cover gaskets along with the spark plug boss seals.
Tuesday, November 2nd, 2010 AT 7:20 PM
Please
login
or
register
to post a reply.
Related Air Filter Replace/Remove Content
I Changed The Air Filter To A K&n, Now The Car Idles...
Check Engine Light Is Steadily On. I Recently Changed My Airfilter To A K&n For Better Airflow And Possibily Better Throttle Response....
Asked by
docuzzie
2005
JAGUAR S-TYPE
GUIDE
Air Filter Replacement
Changing the air filter for your car is easy to do and will save you money as well as help your engine last longer. This filter removes contamination from the air the engine...
Engine Swap
My Engine Blew Up And I Want To Know What Other Engine Be Can I Fit In It?
Asked by
Ednaldo
2000
JAGUAR S-TYPE
2000 Jaguar S-type
I Took My Jaguar In For An Oil Change And Drove It For About Five Hour Afterward And Parked It. The Next Day In The Late Evening Got In And...
Asked by
Ann Jones
1 ANSWER
2000
JAGUAR S-TYPE
2000 Jaguar S-type Jaguar Turns Off At Idle
Shakes Or Wobbles Problem 2000 Jaguar S-type 6 Cyl Automatic I Have A Year 2000 Jaguar S-type. It Shuts Down At Idle. Also When Am...
Asked by
ttinaa
1 ANSWER
2000
JAGUAR S-TYPE
How Do I Diagnose Engine Problem, Whats Quickest...
I Ran Out Of Engine Oil, Heard A Tapping Noise. Started To Get Louder, Contacted Friend, Advised To Check Oil. Filled Up. Oil Looks...
Asked by
unclenik
2000
JAGUAR S-TYPE
VIEW MORE
Symptoms of Low Engine Power
Fix an Engine with Low Power!
Low Engine Power
