1996 Jaguar XJ12 Dead Battery Trunk Won't Open Fix
JAGUAR
TDEWHURST
1996 XJ12 not run over winter, battery dead (no surprise) but I can't open the trunk either with the interior release, key or the push button. If I can't get to the battery, how can I get the trunk open?
Any thoughts appreciated.
Thanks
Jun 30, 2007 at 6:33 AM
2CARPRO JACK
  • 11,533 POSTS
Under the hood, you will see a power point to hook a charger or jumper batttery to, that will light the interior up enough for the trunk release/lock motor to open up. Great design huh?
Jul 1, 2007 at 1:27 AM
3TOMMY
  • 8 POSTS
there is a little key slot on the trunk lid, use the normal driving key (black one), and twist a bit hard, and trunk will open. i dont think what mr. mechanic said would work, unless if you somehow were able to get inside the car, to press the hood release, unless if you went from under which is impossible. the terminal to boost the car, is towards the top of the hood, beside the engine, on the mid right side, mounted near the windshield (that means, if its in north america, im saying its closer to the passengers side than drivers side)
or, use a slim jim to open the passengers door, and then boost the car from cig lighter
Nov 22, 2007 at 5:33 PM
2CARPRO JACK
  • 11,533 POSTS
What "Mr Mechanic" is saying is that the doors will unlock manually, so is the hood release.
Nov 22, 2007 at 11:57 PM
Suggested Repair
Manually unlock the doors and use the manual hood release, then connect a charger or jumper battery to the under-hood power point so the trunk release and lock motor can operate.
Conversation Summary
The owner of a 1996 Jaguar XJ12 stored over winter has a dead battery and cannot open the trunk with the interior release, key, or push button, so the battery is inaccessible. An expert advised using the under-hood power point with a charger or jumper battery to power the trunk lock motor, and clarified that the doors and hood release can be operated manually. Another participant suggested turning the black driving key firmly in the trunk-lid key slot.
