2000 S-type 4.0
2000 JAGUAR
KATIEKAT63
I have a 2000 s-type 4.0 with 80,000 miles and this is actually the first problem I have ever had with the vehicle but I noticed that the trunk switch on the exterior of the car was no longer working. I replaced the switch and realized one of my tag lights wasn't working, upon inspection of the bulb I realized the bulb wasn't blown and my new trunk switch was not getting any power and still wouldn't work. So I am assuming it must be an electrical short. Any ideas? Anyone know how to find the short? My trunk will open if I use my remote or the trunk button inside the car, I checked the fuses and their all ok, and other than the one tag light (which I replaced the bulb as well, and it still didn't work) and my trunk switch everything else seems to be working fine.
Sep 5, 2007 at 12:12 AM
DAVE H
  • 13,384 POSTS
both tag light's receive power from the same fuse so the one that is out must have a break in the wire to that bulb ... the only thing the switch and bulb have in common is they both recieve a ground signal from the REM (rear electronic module)
Oct 25, 2009 at 5:50 AM
