1997 Isuzu Trooper white smoke
162,000 MILES • 6 CYL • 4WD • MANUAL
GILRODJUNE5TH
there is white smoke coming out of my pipe and when I shift into gear the vehicle putters or hops a little. what can be happenning?
and what should I do? Can i still drive it for a while?
Dec 12, 2007 at 4:53 AM
  • 75,988 POSTS
Might mean blown headgasket or crack head/block. Get the tests done below
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
Dec 12, 2007 at 5:17 AM
