1997 Isuzu Trooper Rough Run and Lights
1997 ISUZU
KATIEJAY
First and foremost, I live in Mexico and cannot find anyone who has the proper code reader.
Recently replaced motor with one that was for a standard transmission but they replaced some parts to make it work for my automatic.
check engine light is on and stays on. ABS and brake light comes on it seems whenever I turn to the left and then stays on. At times motor runs very rough and feels like it is in low gear and doesn't want to change out. If I stop, turn off and re-start motor it will run fine - sometimes for days and then do it again. Sometimes the same day, I have to stop, turn off and start again for everything to run right.
Also at times the battery light comes on, the a/c turns off and sometimes but not always, the car looses power and won't go over 10 miles an hour (all at the same time). Turning it off, waiting and starting again will stop this.
I decided to fill up the tank with gasoline and since I did that, I have had no problem with the battery light/ac/motor. Not sure if that indicates fuel pump prob or not.
Just had all injectors checked and calibrated. I do have a trailer wiring harness on the auto.
Sometimes the a/c is hardly putting out cold air - mostly when the car is running rough, thenother times the a/c work perfectly. At times feels like the transmission is slipping.
I know this is alot, but I need help and the Mexican mechanics are trying to figure it out, but no one seems to be able to fix it.
Oct 29, 2007 at 4:13 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8aa7136db6="Katiejay"]First and foremost, I live in Mexico and cannot find anyone who has the proper code reader.
I know this is alot, but I need help and the Mexican mechanics are trying to figure it out, but no one seems to be able to fix it.[/quote:8aa7136db6]
I don’t know if I can help but I will give few suggestions
If you had just replaced the engine and all that happening
Makes me wonder if you have some extra and loose wires didn’t make it to their place
And grounds too
You have to fine place at least they can get you the codes that will take the guess work out of the game
As for the abs still need codes to pin point the area?
check the wiring around the tires and check the rings
Good luck
Oct 29, 2007 at 11:50 AM
KATIEJAY
thank you for the reply. I'll have the wiring checked again. If you happen to know anyone heading down to the Cabo San Lucas area for vacation who can bring a code reader, it would certainly be appreciated.
I live in Todos Santos.
Oct 30, 2007 at 5:13 AM
Suggested Repair
After the engine swap, recheck for loose or misplaced wiring and grounds. Have diagnostic codes read to narrow the check-engine and ABS faults, and inspect ABS wiring around the tires and the tone rings.
Conversation Summary
The owner of a 1997 Isuzu Trooper with a recently swapped engine reports a persistent check-engine light, ABS and brake lights that come on when turning left, intermittent rough running, limp-like power loss, battery and A/C issues, and possible transmission slip. Restarting temporarily clears some symptoms. The expert suggests misplaced or loose wires and grounds from the swap, obtaining diagnostic codes, and checking ABS wiring around the tires and the rings.
