1998 Isuzu Trooper Timing Belt Maintenance
1998 ISUZU
ERIC138109
89,900 miles, 3.5L, never a problem except the occasional check engine light which is usually the result of not screwing the gas cap on tight enough. The only repairs I’ve ever done is to change the oil & air filter. I’m considering getting the timing belt changed as I plan to keep it as long as I can.
What’s the Isuzu’s history on timing belts? Am I messing with a good thing by doing this maintenance? If I do replace the belt should I also replace the water pump? What else should I do?
Thanks in advance!!!
Jun 22, 2006 at 3:41 PM
JOUGH626
  • 55 POSTS
This is pretty much in order of cost, but not in order of importance -
Air Filter
Oil Filter
PCV Valve
Fuel Filter
Radiator Cap
Fuel Cap
Spark Plugs
Trans Filter + Fluid (if automatic)
All belts (to include timing belt, replace your water pump and belt tensioner at the same time as timing belt)
Oxygen Sensors
There is quite a bit more things you can replace at regular intervals, but this is a good start. Good luck!
Jul 11, 2006 at 1:40 PM
Suggested Repair
As preventive maintenance, replace the timing belt together with the water pump and belt tensioner. Also service the air and oil filters, PCV valve, fuel filter, radiator cap, fuel cap, spark plugs, transmission filter and fluid if automatic, and oxygen sensors.
Conversation Summary
The owner of a 1998 Isuzu Trooper with about 89,900 miles and a 3.5L engine asks about timing belt history and whether replacing the belt, water pump, and other items is worthwhile preventive maintenance. An expert lists routine service items and recommends replacing the timing belt along with the water pump and tensioner, plus filters, caps, spark plugs, transmission service if automatic, and oxygen sensors.
