1996 Isuzu Rodeo Question engine not starting
BC3410
  • 1996 ISUZU RODEO
  • 6 CYL
  • 4WD
  • MANUAL
  • 126,000 MILES
When you turn the engine over, it does have spark and fuel; Seems as though the injectors are not opening all the way, but when you prime the engine with fuel it backfires. I am thinking that it might possibly have something to do with either the cam position sensor or crankshaft position sensor.
Thursday, May 27th, 2010 AT 6:25 AM
Check your fuel pressure if its within specs-If there's a problem with those sensors you won't get spark and injection pulses.
Monday, August 26th, 2019 AT 7:07 PM
