i can see water coming out the muffler but I dont see water in the oil or the cylinders, all spark plugs are dryed but black I getting voltage at the fuse box but the fuel pump relay is not showing 12 volts out
i am missing something? I removed the crankshaft sensor and it look brown from oil wear, how can be check for operations? Ohm or volatge?
it will be a greate help thank dan
SPONSORED LINKS
Thursday, March 13th, 2008 AT 9:44 PM
