1991 Isuzu Trooper No Injector Spray
ISUZU
TANDT
1991 Isuzu Trooper, with 2.8 liter V6 also is running the TBI System. Mileage is 137,000. My problem is I have no gas spraying from the injectors. I have on one side of a single injector 12.4 volts with the key on. Nothing with the key off. There is no ground on the other side. The same with both injectors. I can manually feed the system with gasoline and it will start right up. Also, with power applied to the injectors, cranking the motor the injectors will spray.
With a nice cone shaped spray. If you can answer this question, I will donated enough for you to get a six-pack on your way home from work today! I need to figure this out now!! You help would be greatly appreciated, I have no manual on this vehicle. Thanks, again....Big Book of Matches!! :lol:
Mar 29, 2007 at 6:14 AM
JOUGH626
  • 55 POSTS
I guess your saying that you are some how applying the needed power to the injectors and they are spraying fuel. So I guess you already know that the filter is not plugged and the fuel pump is running. Their is something called a "Fuel Injector Resistor", I'm not sure exactly where it is located on your vehicle, but that would be a good place to start.
Next, check all of your relays. There are relays in the fuse boxes and under your dash, double check all of those. There is a "main" relay that controls the fuel pump and may control the injectors.
Apr 5, 2007 at 4:32 PM
Suggested Repair
Check the fuel injector resistor and all relays, including the main relay that may control the fuel pump and injectors. The fuel pump and filter appear to be working, since the injectors spray when power is applied.
Conversation Summary
The owner of a 1991 Isuzu Trooper 2.8 V6 with TBI reports no fuel spray from the injectors. One side of each injector has 12.4 volts with the key on, but the other side has no ground. The engine starts when fuel is fed manually, and the injectors spray when power is applied while cranking. The expert suggests checking the fuel injector resistor and the relays, including the main relay.
