2001 Isuzu Trooper Water Pump Leak
ISUZU
GGFORESTER
2001 Isuzu Trooper V6 3.5 4wd, 126k miles
mechanic showed dried coolant spray on engine just above water pump, diagnosed as leak either from water pump or failing gasket. amount of leakage not enough to drop reservoir level a few ounces below max level. recommends replacing pump, could just be gasket but no way to verify. also recommended replacing timing belt (which was just replaced @ 90k miles). engine runs fine, no overheating problems, my wife maintains this car meticulously. She is now concerned about a failing water pump on an upcoming 500 mile trip, does anybody have any suggestions on how to proceed?
May 16, 2007 at 12:31 PM
2CARPRO JACK
  • 11,533 POSTS
If the water pump wasnt replaced with the first timing belt then I would do it now. Resetting the tension on the pump with a new belt is a sure way to take out the bearing in the pump. The old belt can be used, they just need to mark the direction it was turning to prevent a possible premature failure
May 17, 2007 at 1:04 AM
Suggested Repair
Replace the water pump now if it was not replaced with the previous timing belt. The existing belt can be reused if its rotation direction is marked; fitting a new belt and resetting tension on an old pump can damage the pump bearing.
Conversation Summary
The owner of a 2001 Isuzu Trooper with 126,000 miles reports dried coolant spray just above the water pump. A mechanic suspects a leaking pump or gasket and recommends replacing the pump and timing belt, although the belt was replaced at 90,000 miles and the engine is not overheating. The expert advises replacing the pump if it was not done with the earlier belt and says the old belt can be reused if its direction is marked.
