1995 Isuzu Trooper No Heat, Moonroof Stuck
ISUZU
CHICKYBOO
just bought a 1995 Izuzu Trooper limited with 104,000 miles on lit yesterday. Looks great runns well its' just that the heat does work. It blows cold air what could be the problem? Also moonroof will not open.
Jan 24, 2006 at 3:31 AM
2CARPRO JACK
  • 11,533 POSTS
the heat could be the heater control valve (if so equipped) or the blend dooor under the dash. Sunroof- check for power at the switch
Feb 2, 2006 at 7:33 AM
Suggested Repair
For no heat, check the heater control valve if equipped and the blend door under the dash. For the inoperative moonroof, check for power at the switch.
Conversation Summary
The owner of a 1995 Isuzu Trooper Limited with 104,000 miles reports that the heater blows cold air and the moonroof will not open. The expert suggests the heat problem may be the heater control valve, if equipped, or the blend door under the dash, and recommends checking for power at the moonroof switch.
