Fuel injectors
ISUZU
CHESTER306
1997 Isuzu Rodeo 3.2 v, 50,000 mi
This vehicle has sat for seven years with fuel in the system. I have replace the fuel pump, tank and in-line filter. I now have good fuel pressure up to the fuel header/injectors but cannot get it to run. I have recently removed the injectors and just as I suspected they are dirty from old fuel. Is there any way to clean and check there operation while out of the vehicle? I would like to bypass the $150.00 ea. expense of new ones if possible.
Sep 4, 2007 at 2:03 AM
2CARPRO JACK
  • 11,533 POSTS
You verified spark? After that long the tank needs to be drained and new fuel and possibly a stabilizer added.After you verify spark, get a "noid" light and be sure the injectors are getting pulse
Dec 28, 2007 at 11:24 PM
