1999 Isuzu Trooper EGR Light and Oil Use
ISUZU
JONEAL2201
MY 1999 TROOPER 104000 (5.3L?). CHECK ENGINE LIGHT CALLED FOR EGR. REPLACED, RAN ABOUT 8 MONTHS NO PROBLEMS. RECENTLY CAME ON AGAIN TOOK REPLACEMENT BACK TO PARTS STORE AND GOT NEW ONE, PUT ON. LIGHT CAME BACK ON WITHIN 2 DAYS. ALSO HAVE TO PUT ABOUT 1 QUART OF OIL IN EVERY 3000 MILE OIL CHANGE. ABSOLUTELY DOES NOT SMOKE, NO LEAKS, WHERE IS THE OIL GOING AND COULD THIS HAVE ANYTHING TO DO WITH THE EGR.
Aug 9, 2007 at 9:21 AM
2CARPRO JACK
  • 11,533 POSTS
It is probably burning it while you are driving and cant see it.Try manually applying the EGR valve with a vacuum pump, engine should stumble and almost if not completely die. If it doesnt, then all the oil it is burning has probably plugged up the EGR passages and they must be cleaned out for the system to function properly and the light to stay out
Aug 9, 2007 at 9:32 AM
Suggested Repair
Apply vacuum to the EGR valve with the engine running; it should stumble or stall. If it does not, clean the EGR passages, which oil burning may have plugged, so the system can work and the light stays off.
Conversation Summary
A 1999 Isuzu Trooper owner reports a recurring EGR check-engine light after two valve replacements, plus about one quart of oil use every 3,000 miles with no smoke or visible leaks. The expert says the oil is likely being burned while driving and may have plugged the EGR passages. They recommend testing the valve with a vacuum pump and cleaning the passages if the engine does not stumble.
