2000 Isuzu Trooper P1340 Misfire
The problem with modern day techs without a lot of gray hair, they are lost past what the engine codes reads. In this case one must analyze the engine data and then check out the problems.
The problem with modern day techs without a lot of gray hair, they are lost past what the engine codes reads. In this case one must analyze the engine data and then check out the problems.[/quote:6a1193b73c] Thanks for your help. Rick
Suggested Repair
Have the camshaft and crankshaft position sensors tested and compare their signals in the scan-tool data stream. P1340 and ongoing misfires can indicate an engine synchronization problem rather than the code description alone.
Conversation Summary
The owner of a 2000 Isuzu Trooper reports repeated intake manifold gasket replacements, timing-chain and water-pump work, fuel-system cleaning, new spark plugs, and two oxygen sensors, yet the check-engine light and misfire codes continue. P1340 was described by shops as a cylinder synchronization problem and sometimes flashes during driving. The expert says the code can be misleading and recommends checking the cam and crank sensors while analyzing live sensor data. A later comment speculated about a bent connecting rod, but that was not the expert recommendation.
