1996 Isuzu Rodeo Alternator Not Charging
ISUZU
DURAPAX
After lending my 1996 Isuzu Rodeo to my Brother in law, he left the lights on and killed the battery. We jump started the engine and as soon as the jumper cables were removed the engine died. We tried it again after attaching a volt meter and found that the alternator was not charging at all. I replaced the alternator with a new one and it still does not charge. I was told by the parts dealer that this alternator has an internal regulator and as long as there is power to it, it should charge. The battery has 11.5 volts and all fuses have been checked. The engine is a 3.6 liter V-6 and it has 163000 miles on it.
Feb 24, 2007 at 6:23 AM
GARFIELD
  • 197 POSTS
Check the wire that goes from the alternator to the batteries positiive cable( it will be the wire that is bolted to the alternator) ensuring that you have continuity, if you don't have continuity then check and see if the wire has a fusable link in the wire. Next have your battery tested by a parts store to see if it is still good, I had a similar problem with my durango when the battery when bad.
Feb 24, 2007 at 10:18 PM
Suggested Repair
Check continuity on the wire bolted from the alternator to the battery positive cable. If there is no continuity, inspect that wire for a fusible link. Also have the battery tested at a parts store, since a failed battery can cause the same no-charge symptom.
Conversation Summary
A 1996 Isuzu Rodeo with a 3.6L V6 died after a jump start once the cables were removed, and a voltmeter showed the alternator was not charging. A new alternator did not fix it; the battery read 11.5 volts and the fuses were checked. The expert advised checking continuity on the alternator-to-battery positive wire and any fusible link, and having the battery tested.
