2001 Isuzu Rodeo Spark Plug Access
2001 ISUZU
KRUZOO
Before I break something, can you help me with how to locate and remove the spark plugs from my 2001 Isuzu Rodeo? I have a new set of six plugs ready for installation but where I thought they should go is a gasket of some sort. Help?
Thanks.
Feb 9, 2006 at 3:51 AM
GEARSHIFTER
  • 20 POSTS
Wherever the wires are which there should be six that's where the spark plugs are. Pull the wire off that is on the engine. There should be 3 wires in a row on one side and 3 on the other. Once the you pull the wire off you will see the spark plug. Replace them one at a time because each wire has to go into a certian order in order for the engine to fire properly. Also the spark plug gap must be set right so check in the manual for the correct setting.
Feb 9, 2006 at 4:23 AM
KRUZOO
This engine is different in that the six plugs, three on each side, have a coil-type cover held by two screws. After removing the screws, the plug cover does not want to release. I am not sure waht to do once I get to that point? It cannot be pryed with a flat head screwdriver or just pulled up. I am afraid I will break something if I try to force it.
Feb 9, 2006 at 4:59 AM
GEARSHIFTER
  • 20 POSTS
Yah, I'm not sure about that kind i'd have to ask dad, but i know they are pretty pricey to replace, so don't go prying on anything just yet. Sorry i haven't ever had that kind of a set up in my vehicles.
Feb 10, 2006 at 1:42 AM
KRUZOO
Hey, if your dad has any idea what I can do please let me know. Thanks!
Feb 10, 2006 at 3:28 AM
GEARSHIFTER
  • 20 POSTS
will do.
Feb 10, 2006 at 4:03 AM
JOUGH626
  • 55 POSTS
Your right. Those six things on either side of your engine are coil packs. Those coils are what builds and holds the electrical charge. The spark plugs are under them. After you remove the two screws that hold the coil packs down, they will lift out. With time and heat the boots that go around the ceramic part of the spark will get stuck and hard to remove. My advice to you is let the engine warm, just a little, and then try to disassemable everything. Giving the coil packs a little twist and a pull at the same time will help them release. Also, a word or warning, the spark plug closest to the brake booster will give you the hardest time. You'll need a couple extensions, and a flexable "universal" socket.
Good luck.
Jun 17, 2006 at 12:35 PM
Suggested Repair
The six covers are coil packs, each held by two screws, with the spark plugs underneath. After removing the screws, warm the engine slightly, then twist and pull each coil pack to free the heat-hardened boots rather than prying. Use extensions and a flexible universal socket for the plug nearest the brake booster. Replace the plugs one at a time and set the gap to the manual specification.
Conversation Summary
The owner of a 2001 Isuzu Rodeo could not find the spark plugs and found coil-type covers that would not release after the retaining screws were removed. An initial reply suggested following the plug wires and replacing plugs one at a time with the correct gap. The expert clarified that the covers are coil packs and that the plugs are beneath them. Stuck boots can be released by slightly warming the engine, then twisting and pulling the packs. The plug nearest the brake booster is hardest to reach and may require extensions and a flexible universal socket.
