2002 Isuzu Rodeo Low Idle Stall
2002 ISUZU
KEITH5STRICK
2002 isuzu rodeo, 3.2L, 5sp manual. The car is idling very low and stalling. If I turn on th AC and stop it will completely cut off. If I leave the AC off and stop it will nose dive almost to zero and then bounce back up to about 700 rpm. I've taken this car back to dealer twice under warranty but they did nothing. Now that the warranty is over I took it to a local shop and they replaced the EGR valve.... didn't help. This problem only last for about 20 minutes, after that it runs just fine. I have no check engine lights.
Jun 5, 2007 at 1:15 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like a slow or malfunctioning Idle Speed Control Valve. It controls the idle for the computer.Might also want to try cleaning out the throttle bore around the butterfly with some carb spray and a rag
Jun 6, 2007 at 7:42 AM
Suggested Repair
Inspect the idle speed control valve for slow or faulty operation, and clean the throttle bore around the butterfly with carburetor cleaner and a rag.
Conversation Summary
A 2002 Isuzu Rodeo with a 3.2L and 5-speed manual idles very low and stalls when stopping, especially with the AC on. With the AC off, idle drops near zero and recovers to about 700 rpm. The issue lasts about 20 minutes and then the vehicle runs normally, with no check engine light. The dealer found nothing under warranty, and replacing the EGR valve did not help. The expert suggested a slow or malfunctioning idle speed control valve and cleaning the throttle bore around the butterfly.
