1999 Isuzu Rodeo Idle RPM Fluctuates
Other things that should be changed on a 99 Rodeo.
Oxygen Sensors (all four!)
Spark plugs
Oil pressure sending unit
If you have any other questions, please ask.
Suggested Repair
Replace the fuel filter. Before installing the new filter, cycle the ignition a couple of times to flush fuel from the line. Also consider replacing all four oxygen sensors, the spark plugs, and the oil pressure sending unit.
Conversation Summary
The owner of a 1999 Rodeo reports cold starts that sometimes idle above 2200 rpm and try to creep in drive with the brake applied, plus hot starts where idle hunts between about 1000 and 0 rpm and can stall. Once driving, the vehicle runs normally. The alternator, idle pulley, throttle sensor, and a thermostat gauge were already replaced, and there are no computer codes. An expert who had the same symptoms recommends replacing the fuel filter and flushing the fuel line, and also lists oxygen sensors, spark plugs, and the oil pressure sending unit as items to change.
