2001 Daewoo Lanos High Idle
ALL OTHER MAKES ALL OTHER MODELS
BUTTONSCHOCOLATE
I was wondering if someone could help me. I recently bought a Daewoo Lanos SX, yr 2001, 40k on the clock, right hand drive!
When she is sitting idle the car revs from 1500/min to 2000/min. When I clutch to and put it in car the car revs come down, but when she is idle again the revs go back up. Can you help explain what is wrong?
I have been told it could be how the throttle housing is connected. What do you think?
Please help!!
Jul 22, 2006 at 10:15 AM
MIKEYBDMAN
  • 623 POSTS
I would go under the hood and see if the throttle cable is hanging up. Just find where it attaches to the throttle body, and move it with your hand to see if it moves free. You should find a throttle stop on the body that it hits when you release the cam.
Ok, after you are convinced that the cable is not hanging up, then lets talk about what controls the idle on your car.
The powertrain control module (PCM)/engine control module (ECM) controls the engine idle speed with the Idle Air Control (IAC) valve. To increase the idle speed, the PCM/ECM pulls the IAC pintle away from its seat, allowing more air to pass by the throttle body. To decrease the idle speed, it extends the IAC valve pintle toward its seat, reducing bypass air flow.
They make an IAC tester that allows you to extend and retract the IAC valve. Makes trouble shooting easy. If you fully extend the IAC valve, and the engine is still high, then you may have a vacuum leak causing the problem.
There is a IAC reset procedure, but not sure it is going to fix the problem.
Whenever the battery cable or the PCM/ECM connector or the PCM/ECM fuse is disconnected or replaced, the following idle learn procedure must be performed:
Turn the ignition ON for 5 seconds .
Turn the ignition OFF for 10 seconds .
Start the engine in park/neutral.
Allow the engine to run until the engine coolant is above 85 °C (185 °F) .
Turn the A/C ON for 10 seconds , if equipped.
Turn the A/C OFF for 10 seconds , if equipped.
If the vehicle is equipped with an automatic transaxle, apply the parking brake. While pressing the brake pedal, place the transaxle in D (drive).
Turn the ignition OFF The idle learn procedure is complete.
Hope this helps some.
Jul 22, 2006 at 11:05 AM
Suggested Repair
Check that the throttle cable moves freely and returns to the throttle stop. If it does, test the idle air control (IAC) valve; if the engine still idles high with the IAC fully extended, look for a vacuum leak. An idle-learn procedure can be performed after battery or PCM disconnection, but it may not correct this high idle.
Conversation Summary
The owner of a 2001 Daewoo Lanos SX reports idle speed rising to about 1500-2000 rpm while sitting still, then dropping when the clutch is pressed and a gear is selected before rising again at idle. They wondered whether the throttle housing connection was at fault. The expert advised checking the throttle cable for binding, then testing the IAC valve that the PCM uses to control idle air. A high idle with the IAC fully extended may indicate a vacuum leak. An idle-learn procedure was also provided.
