1994 Other Isuzu Models Coolant system cleaning
1994 ISUZU
177,000 MILES • 4 CYL • 2WD • MANUAL
CHEFD420
I blew the head gasket on my truck last year. A good deal of oil got mixed into the coolant system and some of it has adhered to the overflow and radiator cap. I assume that is the situation throughout. I have had it flushed several times, but that doesn't remove the gunk. Is there a way I could do it at home--or a serive that can remove the buildup? Thanks!
Mar 5, 2008 at 7:51 AM
MASTERTECHTIM
  • 4,750 POSTS
there is a radiator neutralizer by prestone i have used to flush out muddy coolant systems. the process takes hours to do. if you do it exactly the way in the directions it will work. i dont remember the exact part number but i believe the gm dealerships stock it due to the coolant issues they are having with the new coolant. try there and let us know how you make out.
Mar 5, 2008 at 8:27 AM
