I think the cam bad
10,093,000 MILES
BILLFIELDS
What does my four cylinder car (listed above) do when cam goes bad?
Jan 4, 2018 at 7:41 AM
CARADIODOC
  • 34,413 POSTS
Depends on what is wrong with it. If one lobe wore down due to lack of oil, you will have a misfire on that one cylinder. If it broke in the middle, it usually results in a crank/no-start. The cause of that is generally improper repair for a warped cylinder head if the cam shaft is in the head. A warped head will lead to a repeat failure.
Jan 4, 2018 at 8:49 AM
