mass air flow sensor
1986 CHEVROLET CELEBRITY
15,500 MILES • 2.8L • 6 CYL • FWD • AUTOMATIC
SCOOZE007
  • 5 POSTS
The car reads code 13. My check engine light come on. I have the oxygen sensor unplugged. i am putting a new mass air flow sensor on it right now and plugging ever thing in and disconnecting the battery to re code it and then drive it. If the engine light comes on again, what could be wrong with the car?
Sep 27, 2016 at 10:59 PM
AL514
  • 5,654 POSTS
Code P0013???
Sep 27, 2016 at 11:04 PM
SCOOZE007
  • 5 POSTS
What is code poo13
Sep 27, 2016 at 11:07 PM
WRENCHTECH
  • 20,761 POSTS
Good question. They did not have "P" codes in 1986.
Sep 27, 2016 at 11:08 PM
AL514
  • 5,654 POSTS
okay, I found your code 13. took a few minutes. It is Open Oxygen sensor circuit. Obviously from it being unplugged.
AL514
  • 5,654 POSTS
Not sure why your putting a new mass air flow on it? what is happening with the car?
Sep 27, 2016 at 11:10 PM
SCOOZE007
  • 5 POSTS
What do you think could be wrong?
AL514
  • 5,654 POSTS
Sep 27, 2016 at 11:13 PM
AL514
  • 5,654 POSTS
a 1986 with 15,000 miles on it. been sitting a while right?
Sep 27, 2016 at 11:14 PM
SCOOZE007
  • 5 POSTS
I hope the engine light goes out with a new mass air flow sensor but if it does not what could be wrong if the check engine line comes on? We will disconnect the battery to reset it. The car has 150,000,00 miles, I bought the car new. It is a great car when it runs well, it is garage kept and I drive it everyday. I will make sure everything is plugged in. It started hesitating going up a hill. I maintenance this car every 3,000 miles oil changes, tire rotation, the works, this car is well taken care of and maintained.
Sep 27, 2016 at 11:31 PM
AL514
  • 5,654 POSTS
well your code 13 is your oxygen sensor. not the mass air flow. Have you changed the fuel filter at all? spark plugs? any of those type things?
Sep 27, 2016 at 11:43 PM
AL514
  • 5,654 POSTS
if the light comes back on, you will have to pull the code again and let us know what it is.
Sep 27, 2016 at 11:44 PM
SCOOZE007
  • 5 POSTS
I have done all that already.
Sep 27, 2016 at 11:48 PM
AL514
  • 5,654 POSTS
so you plugged the oxygen sensor back in and the code 13 came up? I am a bit confused as to where you are at with your diagnosis.
Sep 27, 2016 at 11:50 PM
