2000 Hyundai Elantra Stuck Spark Plug Boot Fix
HYUNDAI
MDODONOGHUE
I have a Huynday Elantral model year 2000.
112,000 miles
4 cyllinder engine
While changing the spark plugs I realized that one of the rubber boots stayed on one of the plugs. Therefore I am unable to get the spark plug socket onto the plug to loosen it and remove. These plugs are recessed about 8 inches inside a metal tube. I removed the valve cover hoping the tube could be removed. Unfortunately there is no clear way to remove the tube and now I am hopeing you can help. :mrgreen: :mrgreen:
Aug 18, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Take a coat hanger or other thin metal and make a small hook on one end. Stick it between the plug and boot and turn so the hook grabs the rubber boot and pull it out. Might still take a little patience, that is usually how they come out
Aug 19, 2007 at 12:42 AM
Suggested Repair
Form a small hook on a coat hanger or other thin metal wire. Slide it between the spark plug and the stuck rubber boot, turn it so the hook catches the boot, and pull the boot out. Work patiently until the boot releases so a spark plug socket can reach the plug.
Conversation Summary
On a 2000 Hyundai Elantra with about 112,000 miles, a spark plug boot stayed on a recessed plug and blocked the socket. Removing the valve cover did not provide a way to remove the metal tube. The expert advised hooking the rubber boot with a thin wire or coat hanger and pulling it out.
