2001 Hyundai Accent No Start After Stall
HYUNDAI
JOSE.L.WONG
I own a Hyundai accent gs 2001 with a 103thousand miles in it is a 4 cylinder with an engine 1.5L.
My question is as follow. I was driving the vehicle from point A to point B and suddenly the vehicle stop speeding up so I pullover at that time and tow the vehicle back home but now I not even can start the vehicle. I scan the vehicle and the reading was 304, and 343. What can I do to fix the problems? I appreciate your help thank you.
Feb 27, 2007 at 6:31 AM
BRUCE HUNT
  • 3,754 POSTS
I think your camshaft position sensor has failed. I am going to email you a word doc with test instructions, etc.
Feb 27, 2007 at 7:56 AM
JOSE.L.WONG
can you please send a pictures of cmp sensor that way I can start doing the test becuase I have no manual to follow the procedures thank you.
Feb 27, 2007 at 1:49 PM
BRUCE HUNT
  • 3,754 POSTS
I don't have a picture. It is located between the ignition coil and the valve cover. Public library sometimes carries repair manuals. Check that out.
Sensor is a coil that picks up signal for the camshaft by its reaction to the magnet in the camshaft.
Feb 28, 2007 at 3:33 AM
Suggested Repair
Test the camshaft position sensor located between the ignition coil and the valve cover. It is a coil that reads a magnet in the camshaft. Codes 304 and 343 suggest CMP sensor failure; replace the sensor if testing confirms it is bad. A public-library repair manual can provide the test procedure.
Conversation Summary
The owner of a 2001 Hyundai Accent GS 1.5L with about 103,000 miles said the car suddenly stopped accelerating, was towed home, and then would not start. Scan codes were 304 and 343. The expert suspected a failed camshaft position sensor, described it as a coil that picks up a magnet in the camshaft, and said it sits between the ignition coil and the valve cover. No photo was available, and a library repair manual was suggested for the test steps.
