Hyundai Accent Cuts Out While Driving
HYUNDAI
HAMMIE73
my accent is a r reg it starts first time most of the time and drives nicely just recently its started to cut out sudenly while being driven and wont restart off the key i have to push it to get going again ive got three young children and im worried about taking them out in the car as it has become unpredictable any help would be very well appriciated :D
Sep 11, 2007 at 8:37 AM
BRUCE HUNT
  • 3,754 POSTS
Sounds like a starting issue that could be as simple as a bad connection on the cabling to a weak starter or battery. I would start with removing the battery cables and cleaning connections. Then follow the cable examining it and checking the other connections.
Sep 13, 2007 at 6:19 AM
NMW75
  • 5 POSTS
[quote:692ff649ce="hammie73"]my accent is a r reg it starts first time most of the time and drives nicely just recently its started to cut out sudenly while being driven and wont restart off the key i have to push it to get going again ive got three young children and im worried about taking them out in the car as it has become unpredictable any help would be very well appriciated :D[/quote:692ff649ce]
My Accent had the very same issue. I traced the problem to a bad connection on the crank positioner sensor wire harness. I cleaned the connections & applied some electrical grease. Its been fine since.
Oct 1, 2007 at 7:04 AM
Suggested Repair
Clean and inspect the battery cable connections, then check the crankshaft position sensor wiring harness connector. Clean the contacts and apply dielectric grease.
Conversation Summary
A Hyundai Accent starts and drives normally most of the time but recently cuts out suddenly while driving and will not restart with the key until it is push-started. An expert suggested checking for poor battery or starter cable connections. Another owner with the same symptom found a bad crankshaft position sensor harness connection; cleaning it and applying electrical grease resolved the problem.
