1997 Hyundai Tiburon Intermittent No-Start Check
HYUNDAI
KLEAHY
My car is a 1997 Hyundai Tiburon with approx 75000 miles on it. It is the smaller engine (I think it's a 1.7L?)... The problem is that the car will not start intermittently.
The symptoms are:
car will not start but will crank fine, but either doesn't seem to get enough spark/fire, or doesn't get any.
Unfortunately, the only time it has happened (very intermittently) is when my wife has the car. Every time, it will start eventually, either during the same cranking, or after letting it rest for a moment and then trying again. Today, it took my wife 10 minutes to get it started. She let it crank for a very long time, then had given up. Then 5 minutes or so later, she tried again, again with no results. After 10 minutes she tried again and it started.
To me, it has done this only once or twice, and only briefly. Each time, another try was enough for it to start up ok. With me, it seemed like it was trying to start but didn't have fuel (crank, crank, stumble, crank, crank, stumble, etc.). However, I've never been able to reproduce.
I thought it might be the fuel pump, but it's never had hesitation problems, nor has it ever died during driving - highway or otherwise. I thought that fuel supply problems almost always manifest themselves as both difficulty starting AND stalling at high speeds. I've experienced none of the latter EVER in this car.
If you think it is the fuel pump, why doesn't it do it at speed ever?
Thanks,
Kelly
Nov 28, 2006 at 12:49 PM
2CARPRO JACK
  • 11,533 POSTS
sometimes electric motors will get bad spots on the armatures.When this happens the pump wont turn,if it happens to stop on a good spot all is ok.Like when a window motor wont roll up, but then you shut the door and it does.Best bet is to get your hands on a fuel pressure gauge.Drive the car yourself for a while with the gauge on it.When the car wont start,check the gauge to see if there is pressure.Also check the main PCM relay.
Dec 12, 2006 at 11:36 PM
Suggested Repair
Drive with a fuel pressure gauge connected and, when the car will not start, check whether fuel pressure is present. Also inspect the main PCM relay. An electric fuel pump can fail intermittently if its armature stops on a bad spot.
Conversation Summary
The owner of a 1997 Hyundai Tiburon reports intermittent no-starts: the engine cranks but does not fire, then starts after waiting or another attempt. It has never stalled while driving. The expert says a fuel pump motor can stop on a bad armature spot and recommends checking fuel pressure during a no-start and inspecting the main PCM relay.
