I was wondering if both 12mm bolts for the timing belt tensioner need to be tightened? It appears that if you tighten them it would restrict the tensioner from doing its job, but I don't want them to back out (by themselves when running) if I leave them loose enough to allow the spring to apply tension. Any help would be appreciated.
Thanks - Don
Thanks - Don
Nov 15, 2007 at 2:48 AM
