1996 Hyundai Sonata P0110 Code
2011 HYUNDAI
GMWR52
I have a 1996 Hyundai Sonata GL, 4 cylinder, approx., 107K and is in very good condition. I recently had it inspected and it failed because of Code P110. Going here and there and not finding the right answers, and cost is higher than the last place. I was told that my Idle Control Valve needs to be replaced, only to find that the one everybody pulls up is not on my vehicle and may I remind me that the lowest price is $213.59 from Napa. Help me to solve this problem. I don't know what all P-110 covers and doing a little research online, I found a company called Rock Auto Parts and their parts are very reasonable. If you can help me, I will sing at your next wedding. My car has been good to me and when I purchased it, I found out that it was previously owned by a female in Virginia and I am the second owner. I am very pleased with it.
Frustrated in NC
Sep 21, 2007 at 9:08 AM
  • 55,770 POSTS
Thanks for the singing offer, The code supplied p110 is really code p0110. Which is the air intake sensor, inspect to make sure it is connected and the wiring is intact., if so try replacing the air intake sensor w/new and clear codes with an engine scanner, reference page https://www.2carpros.com/dia/index.htm Please let me know what happens, thanks for visiting 2carpros.com
Sep 21, 2007 at 9:18 AM
Suggested Repair
Treat the reported code as P0110 (intake air temperature sensor). Inspect the sensor connector and wiring; if they are intact, replace the intake air sensor and clear the code with a scanner.
Conversation Summary
The owner of a 1996 Hyundai Sonata failed inspection for code P110 and was quoted for an idle control valve that did not match the vehicle. The expert clarified that the code is P0110 for the air intake sensor and advised checking the connection and wiring, then replacing the sensor and clearing codes if the wiring is intact.
