1996 Hyundai Elantra Clanking Noise
HYUNDAI
MIZ.PIZ
My 16 yr. old son owns a 4 cylinder 1996 Hyundai Elantra with 98,000 miles. He tells me that when he starts to accelerate the car makes a clanking noise and then when he reaches a speed of 55mph + the noise stops. Can you give me any ideas to look for. He had to replace his starter about 1 month ago. My son says that this noise is coming from the front end of the car. Thank you in advance for your replies. I can't get his absent father to help me or even look at it. Thank God for people like all of you!!!
Sep 9, 2007 at 7:48 PM
SERVICE WRITER
  • 9,123 POSTS
Without hearing it's hard to say. Hopefully it isn't pinging. More inclined to think a haeatsheild that is loose. Bang on the exhaust with a rubber mallet in various places and see if anything rattles.
Sep 10, 2007 at 12:48 AM
SERVICE WRITER
  • 9,123 POSTS
Did you try rapping on the exhaust?
IF this is a heavier noise, it may be the sheild that is on the engine that covers the flywheel (also where the starter is-maybe it was bent? ) at the transmission.
Try this, put the parking brake on and put your foot on the brake pedal then rev the motor with the accelerator pedal and see if the nosie starts up; look for the source. You need 2 people for this.
Sep 13, 2007 at 10:16 PM
Suggested Repair
Tap the exhaust with a rubber mallet to check for a loose heat shield. Also inspect the flywheel cover near the starter, which may have been bent during the recent starter replacement. With the parking brake set and the brake pedal held, have a helper rev the engine and listen for the noise source.
Conversation Summary
The owner of a 1996 Hyundai Elantra reports a front-end clanking noise during acceleration that stops above about 55 mph. The starter was replaced about a month earlier. Experts suggest a loose exhaust heat shield or a bent flywheel cover near the starter, and recommend tapping the exhaust and a two-person rev test to locate the noise.
